Billinwoodland
Apr 26, 2015Explorer
j-d wrote:
Great writeup!
There always seems to be a gotcha somewhere in these install instructions. That or something doesn't fit just quite right.
The install instructions for a TigerTrak rear track bar didn't make sense till I called and a tech helped me. On a baseplate, the instructions were OK but two of the longer bolts to replace OEM bolts didn't thread in properly. Buggered the nut plates that are part of the vehicle frame. Luckily I could drill through and use still longer bolts with nuts behind.
The tip about the right sequence for nut plates is very helpful.
Glad you got'er done.
Thanks JD!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
