navegator
Jan 07, 2015Explorer
If the towing vehicle has a 7 pin plug, there is a 12v dc pin and a negative or ground pin, if the connecting cord is also a 7 pin connector, all you need to do is run a wire from the connector pin 12v dc to the positive battery on the vehicle with an in line fuse of 10 amps, this wire should be a number 10 or lower number, when you stop over night disconnect the umbilical so that the toads battery is not discharged.
If you only have 4 pin connector, you need to convert to a 7 pin, Ford will not do this, they will not be liable for it.
An automotive electrician can install this.
navegator
navegator
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
