My TT has been plugged in 30 amp shore power for two months . Water level is fine when I tested the voltage it was 12.54 which is a little over 75% .My question is why did it not test 100% full. The ...
Your charger should supply a float voltage of around 13.2 -13.4 volts for a lead acid battery. If that 12.5 voltage was measured with the charger on and the battery connected the float voltage is to low from your charger.
