My TT has been plugged in 30 amp shore power for two months . Water level is fine when I tested the voltage it was 12.54 which is a little over 75% .My question is why did it not test 100% full. The ...
If you measured 12.54 volts while plugged in you have a problem. Could be the converter is shot, lose connection, open fuse, open switch. Need to find the problem.
