My TT has been plugged in 30 amp shore power for two months . Water level is fine when I tested the voltage it was 12.54 which is a little over 75% .My question is why did it not test 100% full. The ...
I am going to assume that you read the voltage with the trailer unplugged and everything turned off in the trailer. If this was the case, there are numerous battery charge tables on the web that indicate 12.54 volts to be about 95% charged, and anything over 12.6 volts is considered to be 100%. I don't think you have a problem.
