dockmasterdave's avatar
Nov 14, 2014
battery choices
I am currently testing my 24 DC. It is a Walmart.
It is a one year old free replacement for the one year old that came with the trailer.
I very seldom boondock.
My trailer is always plugged in when stored (at home).
If I replace with either 1 or 2 group 27 real deep cycle batteries, does it hurt them to not be cycled deeply?
I do not need the battery for starting purposes.
I would like enough power to spend a weekend unplugged without going below 50%.
Does this sound workable?
Thanks for all the great advice.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    If you want to spend a weekend unplugged, I would go with the two group 24 Marine/Deep Cycle batteries like your Wal Mart, Costco, Interstate, etc. While not a "true deep cycle" battery, they should be sufficient. What will really suck the juice is running the furnace all night. If you've got the room, I would go with two of the bigger 27s, but you'd need bigger battery boxes and a bigger tray. I would not boondock with a single 24, but that' just me.
  • I guess my main question wasn't stated very well.
    When I replace my battery with Battery/batteries, does it do harm to a deep cycle to stay fully charged?
    Would I have to learn to do a conditioning charge etc?
  • nickthehunter wrote:
    Dakota98 wrote:
    With no shore power & without a generator, you will probably not get through a full weekend. It purely depends on "how much power" you will be consuming.
    That is certainly not true. I have went a week (actually it was 6-1/2 days)on a Group 24 battery. On other occasions a Group 27 only lasted 3 or 4 days. It all depends on how much you are using int. But in my case, a weekend is no problem. Although I have no real answer if it went/goes below 50% or not. That type of thing just doesn't concern me.
    As I said, "It purely depends on "how much power" will be consumed" If the furnace, lights, frig & sensors are all drawing, then a 50% discharge will occur rapidly. The batteries can be drawn down to 20% without too much harm, but not often & will need to be re-charged soon after & will shorten the life span of the battery.
  • The group 24 is already suspect. With nothing but 2 led lights and co detector on, it goes from 12.7 to 12.1 or 2 overnight.
    I am trying to do my research for when it kicks.
    I would think, without running heat, using 2 group 27 real DC's I should get @ 3 to 4 days.
    Any other guesses gladly accepted
  • The year old group 24 should make a weekend if you use no furnace and minimal lights.
    It may go below 50% and that is OK. Use it up.
  • With no shore power & without a generator, you will probably not get through a full weekend. It purely depends on "how much power" you will be consuming.
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 21, 2026
