wa8yxm
Jan 09, 2014Explorer III
Corrosion and tarnish (Corrosions little brother) is a problem for ALL types of batteries, anyone who says "Switch to ____ batteries is blowing smoke, double smoke if they say AGM (AGM is no better in this area than any other Maintenance free type).
HOWEVER: that said, with AGM/Maintenance free, you need to clean them,, Well perhaps every few years. V/s 2-4 times minimum on wet cells.
There are chemical treated washers you can slip over the terminal before you attach the cables, Anti-Corrosion sprays and such, and many of them do help.
But the only thing that really solves it is frequent inspection and clean as needed.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
