traveylin
Apr 09, 2014Explorer
1, my s-10 would lock the steering whenever the key was in the lock position. I forgot one time and chewed up a pair of front tires in a half mile
2. Why would Ford require that the key be put in the acc position if not to release the steering.
3, consider putting a battery disconnect or pull a fuse for the dash control power.
4. Check your battery on the escape and/ or install one with a larger capacity than the std installed by Ford.
5. Put a charger on the battery to top it off charge wise once every several days. My toad did not get many running hours, to recharge the battery sufficiently
pops
pops
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 20, 2025
