OldF__t
Mar 27, 2018Explorer
dubdub07 wrote:Ava wrote:
Run a 12v wire from the RV to the rear plug and feed it to the battery on the toad. I use a fuse on both sides and a relay to stop current from going both ways when stopped.
Which is WAY more work than the 10mm wrench and pulling the NEG cable.
W
Well you only have to do the wiring job once. From then on it's plug'n'play. You don't have to worry about messing with a wrench and the battery every time you go.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
