dubdub07
Mar 27, 2018Explorer
OldF**t wrote:dubdub07 wrote:Ava wrote:
Run a 12v wire from the RV to the rear plug and feed it to the battery on the toad. I use a fuse on both sides and a relay to stop current from going both ways when stopped.
Which is WAY more work than the 10mm wrench and pulling the NEG cable.
W
Well you only have to do the wiring job once. From then on it's plug'n'play. You don't have to worry about messing with a wrench and the battery every time you go.
Undoing the battery 50 times is easier than rigging the plug and play. And you really don't need it. 10mm wrench and 30 seconds or less. SO easy and safe.
Just my experience. I always do things the easy way and when I sell them that isn't a bunch of stuff I need to worry about taking off.
W
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
