AlwaysDreaming
Apr 18, 2018Explorer
dubdub07 wrote:
Battery connected or not, the Ford tranny is just in neutral and won't go into gear. There is no bearing on the battery versus anything to do with towing. You will need to run a power line for AUX braking, but the reason the battery goes dead is due to the accessory not shutting off because it is in N and not P.
This is a simple tow set up. The Ford needs to be run for 5 min before towing and 5 minutes every 6 hours. You then just put it in N and disconnect the battery. Easy. My SHO follows very nicely and I have had zero issues in 10K towing it.
WW
What do you use for a Braking System? Do you need Power? I have been looking at a surge brake system for a Ford Fiesta which requires no power but I don't think I can run the cable to the brake pedal.
Ready Brute Elite Tow Bar with ReadyBrake. http://www.readybrake.com/store/p4/ReadyBrute%E2%84%A2_Elite_RV_Tow_Bar.html
Thanks
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
