AlwaysDreaming's avatar
Mar 27, 2018
Battery disconnect and Backup for tow vehicle (Ford)
2016 Ford Fiesta
The owners manual has directions on recreational towing of the vehicle.
With battery connected on key in the ON (II) position, and shift to neutral with foot on the brake. A message does come up indicating "transmission ready". Then you turn the ignition OFF (0). When you do this, you can't take the key out and a message is displayed " Vehicle is not in park" and the key cannot be removed. Then disconnect the battery ground terminal.
Is this what you do with your later model Ford Vehicle?
Do we know why you have to disconnect the battery?
This is problematic as you lose all the the memory settings like
Bluetooth connections, radio presets, and other control centers
presets. I also don't think the electronic locks on the doors will
work.
Is there a device you can plug into the cigarette lighter (12V) that will supply enough power to hold up your settings?
Can anyone confirm that there is no anti-theft steering wheel lock on these vehicles? It doesn't appear to be.
Calling Ford direct was no help, I was told they have no "technical department" (ha ha). Getting ready to call the dealer.
  • dubdub07 wrote:
    Ava wrote:
    Run a 12v wire from the RV to the rear plug and feed it to the battery on the toad. I use a fuse on both sides and a relay to stop current from going both ways when stopped.
    Which is WAY more work than the 10mm wrench and pulling the NEG cable.
    W
    Well you only have to do the wiring job once. From then on it's plug'n'play. You don't have to worry about messing with a wrench and the battery every time you go.
    W
  • Run a 12v wire from the RV to the rear plug and feed it to the battery on the toad. I use a fuse on both sides and a relay to stop current from going both ways when stopped.
  • My Taurus battery will die. So I do the steps, leave the key on, and disconnect the NEG terminal.
    William
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
