darsben1 wrote:
But unless there is a separate wire from the converter to the battery the circuit is not complete and NO BATTERY CHARGING CAN TAKE PLACE. It is an open circuit.
The OP could run a separate ground wire from the converter to the negative post of the battery and then charging would take place.
Lights would run off the converter but I would not try to run slides or other heavy draw items.
A separate wire from the converter is no different then having batteries connected. All you've done is eliminate the disconnect switch.
