- RoyBExplorer IIWhen I first got my OFF-ROAD POPUP in 2008 I immediately added three more batteries to it giving me a total of four GP24 Interstate Batteries on the tongue frame.
I was still running my 30AMP Single Stage ELIXIR Converter/charger which only puts out a single 13.6VDC.
It wasn't three weeks later when I also started smelling rotten egg smell and tracked it down to one of the Interstate batteries. It was also getting warm to hot.
I measured the DC VOLTAGE coming from the converter and it was holding 13.6VDC when on SHORE POWER.
I removed the the bad Battery from the bank and it owuld only produce around 4-5VDC. The fluids had been all boiled out and two of the internal cells had shorted out to each other. This battery was beyond repair and was only purchased just a few weeks back.
After seeing all of this I decided right away I needed an UPDATED CONVERTER/CHARGER before using my ELIXIR as a battery charger.
Everyone I talked to told me I needed to get a smart mode converter/charger which uses multi-DC Charging voltages on its output. This is called a smart mode converter/charger.
I replaced the ELIXIR with a WFCO Series 8900 Power Distribnutio Center which had a WF8945 Converter/charger board inside it.
After changing everything out I started using the WF8945 as my converter/charger only to find out it would never go into its smart mode charging voltages which after reading about that I found this was a common flaw with the WF8900 series converter.
I ened up keeping my WF8945 converter installed in the WFCO 8900 series Power Distribution Panel since it was brand new and would use it as a back-up unit. I then purchased a Progressive Dynamic PD-9260C 60AMP Converter/Charger which I installed stand alone very close to the battery bank.
This unit charges my remaining three GP24 Batteries in a quick three hour time frame using the smart mode charging techniques and then falls back to its 13.6VDC Normal mode and will drop to a FLOAT Mode of 13.2VDC when no current is being demanded. The 13,2VDC mode will not boil out battery fluids is left on for long periods of time unlike what 13.6VDC will do.
This is still working today keeping my three GP24 2008 Interstate batteries charged up to their best performance.
Batteries are very important to me especially since I use them camping off the power grids alot. I monitor them on a frequent basis.
I suspect your 1997 RV has suffered the same results...
You will probably need to replace your shorted deep cycle battery but more importantly you also need to replace the converter/charger unit with a modern smart mode unit which will almost take care of your battery automatically. I would still inspect the battery on a schedule basis... This could be a good time to install at least two batteries when you upgrade the converter/charger if you find out it is a single mode 13.6VDC Output model.
You can post the model number on here if you like. We can tell you what you have...
Just my comments here on what happened to me...
Roy Ken - midnightsadieExplorer IIyour battery needs water checked monthly, you,ve most likely burnt it up, time for a new one, clean all post charge new battery before you install. after you install check volts your converter is putting out.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
