OK Fords,
You seem to have two separate issues here:
1-You need to keep the battery up where there is no shore power.
2-You want to be able to disconnect it easily.
The easy answer for 1 - Get a 35$ca solar panel at Canadian Tire and hook it to the battery and leave it where it is.
If you still want to unhook a battery easily with low cost and high reliability, go back to CT and get a pair of marine battery terminals for 14$ca and then change the lugs on the cable ends to suit. Now you have wing nuts.
If you still plan to carry the battery, get a plastic battery box (I bet CT has those too), so the battery doesn't dissolve your clothes and the car interior.
Matt
