DrewE
Mar 17, 2016Explorer III
You need to know the current rating of the shunt as well as its design voltage to figure its resistance; at that point, it's just an application of ohm's law.
If, for instance, it's a 100A 75mV shunt, then .075V = 100 R, or R = .00075 ohm ( that is 0.75 milliohm). Very few multimeters will measure that; the minimum resistance range on my Fluke 73, for example, has a precision of 0.1 ohm.
Before completely blaming the meter, see what it reads with the input short-circuited. With an open circuit input, it may be picking up enough stray charge to read most anything (particularly if it's a digital meter). Checking the calibration of it would be easier by applying a known test voltage in the 0 to 75 mV range.
It's possible for poor contact at the shunt connections to lead to incorrect readings at times, too.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
