sjturbo's avatar
sjturbo
Battery Cable length/resistance?
As several of you know I am putting together 4ea., 6 volt batteries, a 600 watt inverter and a PD9270 on my 5er. I have read that it is very important to make sure that the battery connect for pos. and neg. cable lengths are equal to insure proper charge and discharge rates between the parallel banks. And I assume that applies to the lengths to the converter? And that the cables should be equal length to the inverter? This I assume is all related to total resistance in the positive and negative legs? But since I will have a disconnect, a Victron "shunt", as well as a fuse for the batteries and inverter should I focus on cable lengths that approximate the same resistance or measure resistance of the components and cable... or am I splitting hairs. My intention is to use 2ga or 4ga throughout.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
