Sam_Spade
Jun 14, 2017Explorer
MetalGator wrote:
When I am not using the coach, it is stored in a garage plugged into power .......
OK, so to "fix" the switch, just change the labels. ;)
But then about being continuously plugged in, you REALLY should check the voltage at which your converter "floats" the batteries.
If it is a single stage OEM model, that voltage is probably a bit too high and will tend to "boil" water off the batteries.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
