mrekim
May 04, 2015Explorer
Bearing Question
I asked this in the travel trailer forum in a thread about seals and decided that asking here might be more appropriate:
I repacked the bearings on one side of my trailer that had the factory lube job. The Lippert factory bearing packing job seemed to be pretty good. Bearings were full, seal was full, and plenty of grease around the outer bearing. The wheel had no noticeable play and the nut could be removed by hand.
The bearings, spindles and races looked good with the exception of the inside of all the bearings. They all had this mark on the inside:
I did some reading and I think this is OK, but I wanted to double check before doing the other side. I'd rather redo 2 wheels vs 4 if it turns out this is not good....
