RonWSl's avatar
RonWSl
Belly Pan being uncooperative
I had to drop 2 of my belly pans to address a water leak (2006 KZ Montrego Bay 5th wheel) . The pans are the black plastic sheets which were held in place by screws on the cross pieces of the frame. However, the left and right sides go into a channel/groove, perhaps one inch wide, on either side. I managed to get the panels screwed back in place in the original screw holes (no easy feat); but, the panels are putting up a fight when I try to get the side edges back into the groove/channel. For now, as we are leaving town for a long weekend, I have zip tied the sides at various places, as they were hanging down on the sides a few inches.
What's the secret to getting them to go back into the grooves?
Thanks
Ron S
  • Makes sense - I'll try the grooves first then the screws. I did the screws first to hold them up - - was trying to do it alone. I think I am going to have to draft my friend's son to help - and maybe a board and floor jack as well.
    I was hoping for some magic trick others' experience had taught them.
    Thanks
    Ron S
  • Bobbo's avatar
    Bobbo
    Explorer III
    I agree. The screws are preventing the movement needed to finagle (a technical term, pronounced fin {long} a gull) the pans into proper place.
  • I'm thinking you need to put the panels into the grooves first and then put in the screws.
    Barney
  • I have no experience here so I am just guessing. Lack of flexibility your problem? I'm thinking unscrew them start one side then screw the middle while you work the other side into place.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
