GravelRider's avatar
GravelRider
Explorer II
Jul 22, 2020
Bent sway control on EAZ Lift hitch
Last night I mounted a Camco EAZ Lift WD hitch with sway control to my trailer. Instructions were pretty terrible, but installation seemed to be fairly straightforward, fortunately. I got the WDH installed and setup first, took it for a drive and was happy with the results. I then mounted the sway control. When I pulled out of my driveway, there was some creaking noise, but nothing too loud, then I went around another turn in my street and there was even louder creaking. I stopped and checked out the new sway control and found this:
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
You can't tell in the pictures, but both the main body and the slide bar are bent.
I didn't back up at all with the hitch. I made two turns, one right, one left, neither of which was overly sharp, and certainly what one would encounter in a normal day's drive. After this bent, I read, re-read, measured, and re-measured, and watched YouTube videos, and I'm confident everything was installed correctly.
One thing I noticed when I put it on was that with the on/off handle turned all the way clockwise until threads bottomed out (as instructions say to do), there was absolutely no movement. I wasn't too concerned, because if I was able to move it by hand, how would it provide good sway control? But, what I believe happened is that when I turned, the slide bar did not slide in the main body, and instead bent, as shown in the pictures.
Obviously I'm going to reach out to the manufacturer today. But in the meantime, has this happened to anyone else? Any tips/advice? I'm assuming this was just a manufacturing defect on this one.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
