BarneyS
Jul 22, 2021Nomad
That exact thing has happened before and posted here on the forums. I have not taken the time to look it up but the take-away from the discussion is that Yes, the V formed by the intersection of the driveway and road PLUS the turn you were making put too much pressure on the snap up.
You have a couple of choices to prevent it in the future. I would probably do both if the tongue weight is over 1000lbs.
1. Purchase the heavy duty brackets that have the reinforced top part.
2. Thru bolt those brackets to the frame. Reese has approved this for heavy tongue weight trailers.
I would not worry about the dent in the frame.
Barney
Barney
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
