forumtruckcampe's avatar
Oct 26, 2020
Firestone Ride-Rite Airspring Defective Design Bent Brackets
Hopefully this topic hasn’t already been covered, my search of the forums did not find a similar entry. I’m providing the following to help anyone with similar issues as I couldn’t find much information on the internet from my searching.
I've concluded that the Ride-Rite airsprings for a 2016 Ford F150 have a major design flaw. The truck is a long bed 4x4 that is used to carry a Hallmark Camper (advertised base weight about 1300 lbs dry). I had the dealer install Ride-Rite airsprings given I sometimes go on rough roads. Initially per their recommendation I ran them at 50 psi. I found this led to lurching side to side on rough roads, a rough ride and the rear end jacked way up. Given the truck load capacity (per the specs about 2400 lbs), I started running 25 psi which seemed all the truck needed.
However, when under the truck this year I noted severe bending of the Ride-Rite frame brackets and axle brackets (both sides). Turns out at 25 psi there is only 3/4 travel before the Ride-Rite frame stops contact. Since this can easily occur when on rough roads, the metal to metal contact ends up bending the brackets. To get reasonable clearance requires 50+psi. Then manual does not address that you need enough airpressure to avoid bottoming the brackets when hitting bumps. I believe my understanding is correct based on:
- etrailer.com forum with Firestone response was that brackets will be bent if not enough airpressure is used for the load
- the large number of replacement brackets available at multiple sites
- inspection of my damaged installation at various pressures
In my case, using 50 psi results in undesirable characteristics as noted above. In my opinion the there are several defects in the 2016 F150 design (kit 2582):
- the axle jounce bumper function should be retained (it’s removed in the installation) so that metal to metal contact cannot occur; this is ends up bending the airspring brackets and I assume is not good for the truck suspension
- more travel should be provided at reasonable lower pressures
- the manual should explicitly provide an inflation requirement under load (i.e., maintain x inches (3 inch?) clearance)
My conclusion is limited to this one installation, it may be that other kits don’t have this issue.
Given the cost of ordering new brackets and that I don’t like the ride at higher pressures, I removed them ($500+ down the drain) and installed the Timbren SES severe duty kit. The ride is very much improved. I will note that the Ride-Rite bent brackets ended up locally distorting the truck frame at the attach point. This so happens to be the same as the Timbren SES so the rubber springs were out of alignment (cocked at a concerning angle). I solved this mostly by installing some 3x3 inch quarter inch housing frame washers from Home Depot to bridge the deformed portion of the truck frame.
