3KP
Dec 29, 2015Explorer
Timbrens or Firestone ride rite bags and camper cover?
I recently purchased a slide in camper 2001 Northstar 10.5 XL I own a 91 F350 4x4 crew cab. I noticed when I went over some bumps I got a little hopping/bouncing in the rear. Truck is slightly nose high but not to bad. I was told to put different shocks to take the bounce out. But was also told to put bags on it to take the bounce out. So I started to look into bags and found the Timbrens.
Also want to purchase a camper cover but not sure on the size I need? Camper is 10 1/2 ft bottom and 17 ft across the top.
Any suggestions?
Thank you
Michael
Any suggestions?
Thank you
Michael
I am one that does not favor Timbrens. I do not have a slide in camper but when traveling with my fiver the Timbrens bounced back hard on a big bump. I removed them after one year and copied a home made set of stable loads from someone else on this site. I still have full use of my suspension and utilize my overloads and I got a better ride without worrying about adding air or other air related problems. Just my 2 cents.
