Frozen001
Aug 03, 2021Explorer
Well, I returned home over the weekend, and with the replacement standard bracket and noticed that the new one is beginning to bend. So I decided to get my tongue weight.
Yesterday via the bathroom scale method. In my first measurement, I got 1350lbs of tongue weight. This is with the trailer not fully loaded for a trip. Missing are basically clothing and food items as that is pretty much what we have to pack for a trip. I also will sometimes travel with some water in the fresh tank, so I added about 1/3 of a tank and the tongue weight went up to 1500lbs. Either way, I am looking at DOUBLE the published tongue weight. I understand that the published is basically empty with no propane tanks, battery, etc, but I did not expect it to be double when loaded.
So I am grossly exceeding both my bars, and the standard snap-up brackets (which BTW are rated at 800lbs it appears). Guess I going to move up to the 16K Equalizer setup, as buying the pieces to the Reese are also the same cost. This will get me some increased ground clearance (at least it appears I will).
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
