CA_Traveler
Oct 24, 2018Explorer III
Use the 2018 guides and find a vehicle that meets your needs. Then research the 2019 online or go read the manual at a dealer. And make sure that the base plate and aux brake are available for the 2019. Then do a lot of research for problems that aren't documented by the mfg but have since occurred. If the Brake Buddy power is a issue consider other aux brakes.
I would not want any vehicle that requires disconnecting the battery. But what is your resistance to installing a charge line?
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
