lanerd
Apr 18, 2014Explorer II
garyrita wrote:
My problem is SWAY, what hitch would you long time campers recommend. I know you all won't agree on one type only, but if we can narrow it down to two or three it would be appreciated. I have read about the Andersen no-sway hitch, and the Equal-i-zer anti-sway hitch. Both are more in my price range, the Hensley hitch sounds great but is too expensive for my blood
Thanks so much, Gary
I went from a husky WD with one friction anti-sway bar to two anti-sway bars to a Reese Dual Cam and finally a Hensley. If I had gone with the Hensley first, it would have saved me the $$ i spent on the Husky, anti-sway bars, DC unit and replacement parts for the DC unit and would have paid for almost the full price of my Hensley.
I found a used Hensley on eBay for about half the cost of a new one and used it for seven years before selling my TT. The difference in performance is night and day and made our trips so much more pleasant. Not only did the Hensley totally eliminate all sway problems, it is also very quiet and once you get use to it, much more easy to hook up and remove.
Being friction devices, Dual Cam, Equal-izer only help to control sway, the Hensley eliminates it. You just spent thousands on your new Catalina, I can't believe that you would quibble over another couple thousand that would not only give you the absolute best system available but also increase your traveling safety.
Think about it. Just how much is your families safety worth to you?
Good luck in whatever you decide.
Ron
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
