MM49
Apr 19, 2014Explorer
You won't like to hear it, but it's your truck that is swaying, not the trailer. If you correct the rear suspension the sway will be eliminated. I found this out when I moved from a 2013 Ram 2500 diesel with leaf spring to a 2014 Ram 2500 with coil springs. The 2014 has a rear pan-hard bar with a sway bar. The 2014 pulls much, much better. I would look for a pan-hard bar or a watts link for your truck. I don’t think that you will find one because of the major frame modifications necessary.
MM49
MM49
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
