rockhillmanor
Jan 16, 2018Explorer II
100% spray silicone. IMPORTANT to make sure its 100%.
Just spray on the valve rod pushing it in distributes it.
If your valves stems are getting hard to push in you most likely have paper stuck around them. Even just the tiniest pieces of tp paper in the grooves of the blade will make it hare to open and close.
First "Dump Tanks". :W
And then just pick up a bottle brush from the store and open the valve blade and run the brush around where they slide up and down in. You will be surprised how much paper you will find in those small grooves. Which makes it hard to open and close them.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
