brittsnbirds's avatar
brittsnbirds
Best Shocks?
Wondered if anyone had the "hot" set up with their 2500 HD Chevy pulling a 5th wheel.
Currently have a Curt Q20 in the bed. Installed the Rancho adjustable shocks and Firestone airbags to cut down the bounce and bottoming out.
The airbags made a significant improvement to cut down on bottoming out but still have some bounce. I crank the Rancho's all the way up for dampening when I pull.
I called Firestone and spoke with them about better shocks. They said I have the best that I could hope for. Would like to do better on the bounce.
Any ideas?
  • Have to agree with the others, Bilsteins because of their design stops over rebounding and It puts a stop to porpoising.
    I have used them on all of my heavy vehicles and they have performed better than any others.
    E Shocks is the cheapest and most reliable place to buy them. They will answer any questions that you may have.
  • RAS43 wrote:
    Bilsteins. I never had much luck with Ranchos or any adjustable shock.
    Exactly the same story here.
    I found that the Bills have better rebound dampening and that's very helpful to keep the back of the truck under control with a heavy load.
  • More infö….What your pulling?, speed? Pressure in bags?
  • JMO but if your 9000's are in good working condition then Bilstiens probably won't make enough of a difference. Sounds like you have some other issue causing the bounce. Maybe an air hitch would be money better spent.
  • RAS43's avatar
    RAS43
    Explorer III
Looking for advice before your next adventure? Look no further.25,114 PostsLatest Activity: Feb 22, 2025
