- eichacsjExplorer
kaz442 wrote:
Looking for a small electric heater. What are the safest models?
Thanks JKaz
The one you don't use in an RV.
What is your main goal. To burn down your RV or freeze the plumbing.(both rhetorical)
Seen to many after effects of portable heaters. - myredracerExplorer II
SoundGuy wrote:
myredracer wrote:
If you are able to do a bit of wiring, another option altogether is to install a "kickspace" heater below the range. This particular brand is the same width as the stove. I just removed the original piece of wood between the door and range and moved the door down a little. With a heater like this, it's completely out of the way and has all the required safety clearances. The location of your panel could be a deciding factor tho. If needed, wiring can be run through a ceiling and inside interior wall cavities. This heater is very quiet and you can listen to the TV no problem.
Great solution! Got a brand name / model for that heater? :@
It's made by Stelpro. There are about 5-6 manufacturers of these and they vary in width. King makes a good one that has adjustable tap settings of 250 to 1500 watts but is only 17 1/2" wide. Our range opening is 21 1/2" wide. - DakzukiExplorer IIThe best portable small heater with a fan I have found to date is the little Broan 6201 cube. I had a couple of other small ceramic heaters with fans that I bought at big box stores and they were garbage. The Broan is built like a tank and is very small. For non fan heaters, I have worn out two oil filled heaters (the switch/thermostat assembly overheated and failed) so I now have a Delonghi HMP1500 mica panel heater that I've used for several years now. While slightly larger in HxW than an oil heater it weighs much less. That is our go to heater when we are winter RVing and want it to be dead quiet. We Have the Delonghi plugged into a Lux WIN100 programmable thermostat that sits in an outlet.
- SoundGuyExplorer
MrWizard wrote:
Most are around 1500 watts which is 12.5 amps at 120vac ...
In theory yes but in reality hardly does any electric heater advertised or labelled as "1500 watts" actually consume that much power, in some cases much less. I have a gaggle of so-called "1500 watt" electric heaters and only one of them comes anywhere near close to drawing 1500 watts, rather ~ 1440 watts, with all the rest much less. My Kill-a-Watt meter is a handy device for measuring actual draw like this. :) - beemerphile1Explorer
travelnutz wrote:
...for all practical purposes using 117 AC is approx 340 BTU's for each 100 watts consumed. 1500 watts = 5120 BTU's capability, 1000 watts = 3400 BTU's, 750 watts = 2550 BTU's. Just for a quick reference.....
True and it is the same for a $500 "Amish Built" heater or a $10 Walmart heater. The heat output and the electrical consumption is identical. - BumpyroadExplorer
mike-s wrote:
I like the small ceramic heaters - the heating element doesn't get as hot as the old nichrome wire heaters, which makes them a bit safer. Some of them have a lower power setting. All UL listed space heaters are required to have "tip over" safety shutoffs.
those ceramic heaters can singe a bed spread if it is sitting on the floor and you happen to kick the covers off. don't ask how I know this.
bumpy - FunnyCamperExplorer IIwhen we had an enclosed toybox in our 40 ft 5th---it was always cold back there (it was the kid's room when camping) so we bought a 1200 watt oil radiator from a box store, Target or such? Not expensive at all and warms up the place so nicely! Silent and perfect.
We went smaller into a 34 ft toyhauler tagalong, I doubt we will need to use it anymore other than to save propane? Not sure if we will use it this season, will see on that but one thing I know, they last forever and they do what is needed. - MrWizardModeratorHow small, size ? Power ? Or both ?
Most are around 1500 watts which is 12.5 amps at 120vac , some have a lower heat setting
Like 900w or 700w
I have a Lasko personal size desk heater
Only 200 Watts, that I some times use under my desk at night in the winter
Good for my legs and feet, or maybe taking the chill out of the kitchen
But it won't warm the the whole RV
Some times run it off inverter while driving in the winter, to make a warm spot for the Fur kids
Etc.. - travelnutzExplorer IIThink about it! 2 electric cube heaters running on low selection (750-800 watts or slightly higher, 6 amps +) are a lot safer as to being a fire hazard/wiring load potential issues than having just one electric heater drawing 1500 watts from one 15 amp circuit and having the one heater getting much hotter. Also gives true zone control for desired temperature in both areas and overall. Also provides a real backup on hand heater situation incase the just having of one fails in the nighttime when stores near a CG are usually closed. Called - being prepared and smarter/safer RV'ing!
- SoundGuyExplorer
Looking for advice before your next adventure? Look no further.25,156 PostsLatest Activity: Aug 13, 2025
