Tom_Barb
Jun 30, 2018Explorer II
lizzie wrote:
For the past two year we have towed a KIA Soul on a dolly behind our Sprinter based Class C-. We have both had orthopedic surgeries this year and decided that flat towing is best for us. I bought a 2-door Jeep Wrangler Sport today and now we need to fit it out for towing. I would like advice about the easiest system available. lizzie
Remember your jeep is light, you don't need a massive tow bar, or an expensive one either. A falcon 2 works very well on ours. Brakes will depend on what system your coach has. lights? go with CoolTech harness. Their harness plugs into the 7 pin connector on your coach.
Always check to see if the steering lock will allow the jeep to be towed with the key off, place the transfer case in neutral , transmission in gear/park, and off you go.
When the key is in the off position and the steering is locked, disconnect the battery and turn the key to "on" and then tow.
Light harness for jeeps
