- dleslie125ExplorerOh, BTW, to tow, just like the Tahoe we had. Transfer case in Neutral, transmission in park, take out the key and lock the door. No having to worry about running the engine and going through the gears periodically and watching the fluid temp.
- the_silverbackExplorerX3 on the ford edge. I have towed mine 27,000 miles. no problems.
- jerseyjimExplorerFWIW I tow a 2011 Ranger 4WD automatic. Had to buy the "transfer case disconnect kit"...a Ford only item. They installed it....400 bucks.
No problems. I also tow a 2007 Chevy HHR Automatic. Simply pull a fuse and go.
I found that GM has the most 4WD friendly models in most price ranges. But, I wanted what I wanted and the Ranger is it for me.
g'luck in your search! - islandvagabondsExplorerX4 on the Edge. I have towed my 2010 AWD 25000 miles so far with no problems. So far I have been able to go almost evrywhere my 4wd friends have gone. Install the Roadmaster air brake system. It works great and is easy to set up each time.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
