Anonymous
Dutch_12078
Sep 02, 2023Explorer III
henleyd wrote:
After hip surgeries, can still do most things, but have trouble getting down low. I want to tow using a tow bar rather than trailers, dolly, etc. they seem fairly easy, but which bar setup requires the least effort getting down low? N
SA, Blue ox, Roadmaster..?
I'm slowly recovering from a stroke last spring that affects my walking, balance, and manual dexterity. I still manage to handle our motorhome including hooking up the toad.
I only have to bend at the waist some to hook up our Blue Ox tow bar and cables, but a lot depends on how low or high the base plate installed on the toad connection points are. That varies from model to model toad as well the brand and model of the base plate. The Blue Ox base plate on our RAV4 extends the tow bar connection points through the grill about 20" off the ground. Some other brands bring the connection points out under the front valance, just a few inched off the ground. Whether a Blue Ox setup would be best for your situation would take some serious investigation and comparison on your part. Don't forget a braking system for the toad also. Some take more work to install each time you travel, while others have a one time installation followed by a simple cable, quick disconnect, etc. at hook up time.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
