JBarca
Oct 30, 2013Nomad II
Tin Pusher wrote:
JBarca, good if you can do it. Some campers (mine for example) axles are too close together. Tried it, didn't trust it.
H'mm, OK, May not work in all cases. Scales may be part of it.
In my case my 32 " axles centers allowed me to do it and I could verify it worked correct. I had extra weights so the one weight of all 4 wheels did equal the sum of the 4 individual wheel weights, within scale tolerance that is.
Good point to cross verify the individual weights to the total of all 4 weights. If they agree your good, if not, well there is error somewhere and suspect
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 21, 2026
