Old-Biscuit
Nov 08, 2020Explorer III
Had one of those Camco Water Filler that you attach to your hose then stick down into gravity port to fill fresh water tank
Second time I used it the Tube blew off.....been inside my fresh water tank since 2008
Plastic tube inside your Water Heater????
I can see several issues:
Getting hung up on one of the Dip Tubes
Banging around breaking one of the DIP Tubes
Getting stuck in drain hole and blocking draining of tank
If Suburban ....easy to remove the electric element and give you larger hole to retrieve it from
Same if Atwood ...access not as easy due to element being installed from backside of tank
Either way....I would remove it
CAMCO......CHEAP, JUNK and I refuse to purcahse anything from CAMCO
HINT:
In further to flush water heater
Turn water supply off
Relive System Pressure...open faucet hotside
Remove drain plug
Turn Water Supply ON...FULL
Stand back and let it BLAST out the drain hole
*Cold inlet dip tube points downward and will stir up sediment on bottom of tank
HINT:
Remove drain plug
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
