Old-Biscuit
Nov 08, 2020Explorer III
If Atwood drain hole is only 1/2" opening...may be too small to use grabber and pull tube out
Suburban has 3/4" drain hole and MIGHT be able to use grabber
Personally I would remove element ...1" Opening
Plastic....Suburban WH it could get stuck between combustion/exhaust 'U' tube which is STACKED on top of each other.
Plastic up against combustion/exhaust 'U' Tube can melt
Less chance with Atwood due to diagonal 'U' Tube...
Water temps could reach 170*/180*F if T-STAT Fails which could make that cheap plastic very soft/pliable (heck 130*/140*F might also...don't know temp rating of that cheap plastic)
Remove it...be done with it....why leave it to cause problems
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
