BarneyS
Nov 08, 2020Nomad
Yes, I drain the one in my house every few years to get any rust or other crud out of the bottom of the tank. Have done that routine for about 60 years or so. :E
After a year of use, you would be amazed at what comes out of the water heater if you blast some water around in there. It depends on where you camp and what the quality of the water is in your rig but most campgrounds have relatively hard water which leaves white deposits behind on the heating rods and other parts of the heater.
I have had as much as a whole cup or more of the crud break loose and come out of mine after camping for the summer and then spending the winter in a campground in Florida. I would always clean and drain the water heater before we returned to Michigan in the spring.
I just use the Camco wand with the J bend at the end. It provides a lot of velocity to the water which breaks up the crud inside. Mine is probably 10 or 12 years old and will definitely look at it closely next spring when our trailer is opened up again to be sure the tube is securely fastened.
I also have one of those long wire grippers as was linked. It is used a lot to get coins out of my wifes clothes dryer here at home and have used it for many other purposes also. A must have in anyone's toolbox in my opinion. :)
Barney
Barney
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
