tmmar
May 30, 2013Explorer
Are you sure that is not empty? You can get false readings from the tank level gauge if there is something caught on the sensor in the tank. Try filling with clean water and draining again to see if that will dislodge anything on the internal tank sensor. Also, do you have a black tank flush? If so, you should try flushing the tank with that.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
