wa8yxm
May 30, 2013Explorer III
What you are seeing is normal operation of the sensors. the tank is empty, the sensors only work one time when new or one time after a power cleaning.
If you want the true level there are better sensors out there.
Horst Miracle probes are supposed to be better, I plan on installing later this summer.
SEE LEVEL works. and does not false, or so I am told, However it is expensive.
Of course any sensor system can fail due to a technical issue.
But the stock one, Slime on the walls, A piece of paper, anything that keeps the nail moist will false it.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
