rockhillmanor
May 30, 2013Explorer II
Fill with water dump. Fill with water dump.
That should take care of the pesky grundge that is now stuck on the sensor.
That usually happens when all you do is use the tank and dump without running a tank of water after each dump. No wand, special concoction added or whirrly gig needed....just a routine tank of water after each dump does the job.
When you are at a CG it takes all of 5 10 minutes to dump the tank and fill with water and dump again! I use my bathroom sink faucet to fill the black tank no fuss no muss.
I swear I must be the only one that the sensors work all the time. But I do believe it's because I run a tank of water after each dump! :B
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
