DE88ROX
May 30, 2013Explorer
Ritkei wrote:
After 4 days of camping we have a full holding tank. I open the black valve and hear a rush of fluids for about 1 min, then nothing. Check the tank level inside and it shows 2/3 full. After searching I found a post that suggested filling all grey tanks and pull all the valves at same time, causing enough of a vacuum to get the holding tank to drain. This worked once and now I'm stuck at 2/3 full again. Never seems to drain below 2/3 full. Any ideas or tips tricks?
Sounds to me like you have a bad sensor. I just replaced mine and noticed on one of the sensors I pulled from the black tank that it was all crusty. Most oem sensor are nothing more than a little button type stud that sits against the wall of your tanks. Any fluid running down the sidewall will come in contact with the sensor and send out a reading.
get yourself one of these its the only sure fire way to know when nothing more is coming out of your tanks. Plus, if you have a black tank rinse you will be able to know when its "clean" when you start to see clear water running out.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
