gotsmart
May 31, 2013Explorer
Ritkei wrote:
After 4 days ... Any ideas or tips tricks?
Yes, connect a second hose to the tank rinser when dumping.
2012 Keystone Alpine EXTERIOR FEATURES:
•--- MAX TURN high-gloss fiberglass front cap & rear featuring
•30% better turning radius
•Aerodynamic design w 18% better drag efficiency
•Hitch Assist back up mirror w lights
•High Gloss exterior sidewalls baggage doors and entry door
•Class A style dual latch slam baggage doors
•Keyless Entry
•Easy open 4-step entry steps w recessed rope lighting for visibility
•Super-size 64 tall 30 wide entry door
•Motion activated porch lighting
•Deluxe Graphics package
•High Gloss fiberglass rear cap
•Reverse (back up) lights
•One piece polypropylene underbelly
•Triple insulated ducted and heated holding tanks
•---All-IN-One Waterworks exterior utility center featuring
•Easy siphon winterization system
•Water heater bypass
•Enclosed low point drain valves
•Ducted heat for cold weather protection
•Dump valves
•Soap dispenser
•110V outlet
•Black tank spray hookup
•16 E-load radial tires w 8 wheel lugs
•Heavy duty 7000lb axles
•Easy lube axles
•12 -Beams with Z-frame technology
•---Equa Flex Suspension featuring
•Improved impact absorption
•Improved axle equalization
•Greasable wet bolts
•Long lasting 12 steel shackle plates
•Long lasting bronze bushings
•No Sweat vented attic system
•50AMP service w detachable power cord
•Hydraulic selector valves for slideouts
•Hydraulic front landing jacks w 8 diameter all-terrain landing pads
•Gutters w rain spouts
•Rear Ladder
•One-Touch electric awning package w adjustable arms
•Tinted 80% safety-glass windows
•Electric rear jacks
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
