Lantley
Jun 10, 2023Nomad
LouLawrence wrote:
By far, if you want to use chemicals, Happy Camper is the best! The size of your tanks and how often you dump will determine what's right for you. The larger the tank the LESS likely chemicals will be necessary. You will just need to use plenty of water when flushing. Dump when the tank is approaching full. I have been traveling full time since 2000 and use no chemicals. If I sit for more than a month or 2 I throw in some Happy Camper in both black and grey as I think it helps keeps the sensors cleaner.
This is my thought as well. I have found there is really no need to obsess over having a spotless tank, Your just going to fil it with **** all over again.
Lots of water, dump when full, rinse occasionally when at a FHU site, never rinse at the dump station if there is a line!
I'll repeat never rinse at the dump station if there is a line!
You will be fine!
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
