aftermath
Jun 12, 2023Explorer III
I say we go for 5 pages with this fascinating topic. OK, the only thing I want to point out is that this tank you carry around is NOT, NOT, NOT a septic tank. It is a holding tank. There are two completely different functions here. If you believe that all the good bacteria needs to be in place to digest the contents of the tank so that it will take care of all smells then I would like to ask where is your drain field to handle the digested liquid. Pretty silly concept, I know. Do you use chemicals? It is a yes or no sort of thing. The real question is how to you handle potential odors in your system. Some use chemicals and others simply use lots of water and empty tanks regularly. I do believe that both work. If you don't want to use chemicals, use water.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
