opnspaces
Jun 13, 2023Navigator III
chops1sc wrote:
I am 1000% in favor of using as much water as you can while using the camper. But if the camper is in storage mode, I feel like a chemical would help with the smell.
Are you getting a smell when you first open the door after the trailer has been sitting for a while? Or are you getting the smell when flushing the toilet?
If when first opening the door to the trailer, it's very possible you're getting gray tank smell.
If you only get the smell when flushing definitely make sure any and all vent fans are turned off before using the bathroom. You can always turn the vent back on just after you flush. A fan will pull stink out of the tank when the flush valve opens. Aside from that, if water is not working then yes you might need to look into adding a chemical.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
