way2roll
Jun 14, 2023Trailblazer
HappyKayakers wrote:
Everything has a measurable impact on water supply. Letting the water run while brushing your teeth, using an irrigation system on your lawn that floods the street, and yes, black tank flushing. While each of these has minimal impact, add them all up (plus the hundreds of other ways we waste water) and you make a difference. It's the same principle as backpackers drilling holes in their toothbrush handles. Grams make ounces and ounces make pounds. The attitude of 'if it doesn't make a major difference, it doesn't matter' is self defeating.
way2roll wrote:
Are you guys seriously trying to say that RV black tanks have any measurable impacts to water supply and demand and droughts? And further that black tank treatments and chemicals will solve this issue?
Some folks pick odd hills to plant a flag on. I appreciate the concern. I am still not going to use black tank chemicals and as much water is needed. My feeling is that water helps the breakdown process so when it gets to the leech field or treatment plant, less energy and water is required to break things down and remove the very chemicals that were added unnecessarily. Add to that, an RV toilet and subsequent black tank uses considerably less water than a sticks and bricks one. To each his own, I'll pass on the preaching session though. I'm not sold on your logic regarding RV black tank's impacts to droughts. It's probably the opposite by comparison. In any event, this whole debate is really silly.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
