KenNTennessee's avatar
Jul 12, 2014
Black vs. White A/c shrouds
I saw an earlier thread from April 2014 on this, but could not find it through search. I was interested in a post by Luke Porter on 4/17 that said the black shroud was 31% less efficient and raised the output temperature by 7 degrees. I believe it, but would like to know where he got that technical data.
My new 2014 Sun Valley 26' has a black Coleman Mach 3 unit with a black shroud, and it just is not able to keep up. We are on an extended trip, about 9 weeks so far, and when the outside temperature is over 90, it just can't cool down the trailer. Our previous unit was a 2009 23' Rockwood with a Dometic 13,500 unit, and we camped in Texas in August when it was 107 outside, and it stayed comfortable inside. Both units were 13,500 BTU capacity. I realize this unit is longer, but at least by manufacturer's claim has a higher r-value insulation.
I know that the unit is not cooling outside air, and I know that the condenser coils are fan cooled, but the black shroud is much hotter than the white one, so the unit can not be as efficient.
I'm hinking of upgrading to a Mach 15 with a white shroud. Not sure if the 1500 btu gain is worth the money, and the cfm spec per Coleman is 325 vs. 320 for our current unit. Big price for a little difference in specs, but I need to do something.
Would I be better off just buying a white shroud? If that would give me a 30% increase in efficiency, that's more than the 11% capacity increase by going to the Mach 15. any thoughts?
  • I'm sorry to hear that your A/C is not working correctly, and there are many things that can affect the performance of your A/C unit, but the color of the shroud is not one of them.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 11, 2026
