StarcraftNick's avatar
Nov 16, 2017
Battery wires- black white and green
i bought a used 2015 starcraft ar-one and I go to install the battery and there are black, white, and green wires. I can see that white is the ground, so i hook that to the negative and from what i understand the black to the positive. The green wire has a fuse on it so i am under the impression that also goes on the positive. Can someone tell me what the green wire is for? what should all work with the battery hooked up? thanks.
