et2's avatar
et2
Blue line sewer connectors
Anyone else have issues with the connector at the trailer. I've bought new ones and they still leak right at the o-ring. My Flushking fits fine without leaking. Everyone I have (3) leaks the same way. It does have the 4 fingers or prongs to hold it on.
This is the Blue line hose system. The connectors work great except for the one which mounts to the trailer and the hose is pushed over it.
It seems like if they tightened the fingers a little it would be fine. Other systems won't fit into my sewer storage tube on my camper. This is why I use this system.
  • super_camper wrote:
    ScottG wrote:
    I've had mine for about 5 years and it has never leaked.
    There's something strange going on there!
    x2. No problems at all with mine after 5 years
    Actually mine have leaked on my last camper as well as this one. It didn't matter if they were new or not. It's just the connection to the trailer that leaks.
  • rvten wrote:
    I use the Blue Line. But not there connector at the RV conn.
    Just a plain old black conn. I like the Blue Line. Easy to add ectra hose as needed.
    This is what I do also. The four finger connector always leaked on mine too so I use the two finger connector on the RV outlet.
  • After the blue line connector came apart while dumping,I pitched the whole system and got one that cost more,but no more leaks of separations.
    Thank goodness,I was dumping grey water when the connector broke loose.
    ( That was the connector between two lengths of hose.)
  • I use the Blue Line. But not there connector at the RV conn.
  • I've had mine for about 5 years and it has never leaked.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
